Converting text from file to numeric array
Why i have error?
Message 11 of 27
(2,807 Views)
You have to right click on Read Text File and select "Read Lines" like Crossrulz mentioned.
Message 12 of 27
(2,801 Views)
Is almost ok, but i have values: 9, 9, 9, 9, 9, 10, 10, 10. In file i have
9,243
9,445
9,632
9,805
9,963
10,107
10,236
10,351
Message 13 of 27
(2,797 Views)
Do you use commas as the decimal point or the thousands separator?
Message 14 of 27
(2,791 Views)
Yes
Message 15 of 27
(2,788 Views)
That sounds like a terrible system!
Message 16 of 27
(2,784 Views)
no no no, is exercise to school
Message 17 of 27
(2,778 Views)
Seriously though, do you read 9,243 as:
Nine thousand two hundred forty three
OR
Nine and two hundred forty three thousandths? (slightly greater than the number 9)
Message 18 of 27
(2,774 Views)
I see. I always found I learned the most by struggling with a problem for a long time, even if I didn't get the right answer! It is a good approach for LabVIEW too.
Message 19 of 27
(2,771 Views)
9,243 is 9.243, i need number with point
Use Search and Replace String?
Message 20 of 27
(2,758 Views)
