Converting string to number
Here is a screen shot & VI
Message 11 of 17
(1,921 Views)
Neither of your attached VI's have the data saved into the string as a default.  They are still empty.  So I'll look at your screen shot that now shows the string.
The reason is because the function you are using is intended to look for a single number and treat it as a decimal whole number.  You have a space which means the first number has ended.
You need to strip the spaces out of the string before converting.  Then you need Scan from String with %b has the format string.
Message 12 of 17
(1,914 Views)
I want the number to be 1000101011111 not 4447
Message 13 of 17
(1,906 Views)
Then change the display format of the numeric indicator to binary instead of decimal.
You dont actually expect a string of "11111111" as a series of 1's in binary to be converted to the number 11,111,111  (11 million +) in decimal, do you?
Message 14 of 17
(1,898 Views)
No
Iexpect a string of "11111111" as a series of 1's in binary to be converted to the number 11111111  in binary but even after search& replace then scan .. the output is wrong
Message 15 of 17
(1,884 Views)
The output is not at all wrong. Decimal 4447 is equal to binary 1000101011111 which is something basic that you should understand. Whether you display a number in decimal, hex, binary, octal, etc., it's exactly the same number. The display format of a front panel indicator is not going to change the number which is also something basic that you don't seem to understand.
Message 16 of 17
(1,876 Views)
Accepted by topic author MarinaNashaat
@MarinaNashaat wrote:
No
The output is NOT wrong.  Your indicator is set to display decimal.  If you want it to display 1's and 0's, change it to display binary.
Does this make it clearer?
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 17 of 17
(1,868 Views)
