Converting column of Dates
I want to extract the DD/MM/YYYY from the excel file attached into LabVIEW
The example I attach uses variant- however I'm open to using anything- I merely want to convert a date form which I can use as an X axis for my graphs.
Message 1 of 14
(2,031 Views)
Followed Converting Excel Date/Time Values to DIAdem and LabVIEW Values but not sure why it is off by four hours or a day.
https://tmesystems.net/
Message 2 of 14
(2,009 Views)
Timezone settings may apply…
Message 3 of 14
(1,972 Views)
Note: The For Loop is unnecessary:
Same:
Message 4 of 14
(1,948 Views)
Thank you very much, very kind of you know show me that..
I was wondering if I could impose upon you folks once more..
I've attached the same excel spreadsheet but I've added an extra column for Y axis data would you be kind enough to modify the same VI and include an XY display where the X axis is the date?
It's probably trivial but that's where I'm struggling
Message 5 of 14
(1,939 Views)
Hi LED,
  1. Convert the first column to timestamps.
  2. Convert the 2nd column to an array of DBL.
  3. Use Bundle to create a cluster of [timestamp array, DBL array].
  4. Wire that cluster to a XY graph…
What have you tried and where are you stuck?
Message 6 of 14
(1,935 Views)
Everything's going fine as far as adding the timestamped X axis
I almost feel embarrassed to ask this now but if you could turn me on to one more thing I would very much appreciate it.
I want to be able to display multiple graphs in either XY graph or waveform chart maintaining the X axis time in either case.
Message 7 of 14
(1,899 Views)
Hi LED,
When you want to plot mot than one plot in your graph then you should create an array of plots…
Message 8 of 14
(1,879 Views)
The LabVIEW Help system is (or, "used to be" -- I'm currently using LabVIEW 2019) pretty complete.  If you look up Graphs and Charts, it discusses how to plot multiple "channels" (it's pretty straight-forward).  There are also multiple Tutorial materials available, including links on the first page of this Forum, and the Web.
You can "look it up" ...
Message 9 of 14
(1,856 Views)
okay thank you   🙂
Message 10 of 14
(1,810 Views)
