Converting binary input into a constellation diagram
Hi
I am using the MT Format constellation vi for generating a constellation diagram. The input signal is a multitone signal with 3 tones. I am not able to give this input to the vi. Is there any other vi that I could use? Also can I convert the multitone signal into a binary input for the vi.
Thank you.
(3,869 Views)
Did you ever find an answer to this? I'm having the same issue
(3,773 Views)
You need to be a bit more specific.
What signal are you trying to convert?  Can you post an example with data?
"Should be" isn't "Is" -Jay
(3,762 Views)
Where did you get the MT Format constellation vi???
Is it part of an add-on pkg?
(3,729 Views)
It's part of the Modulation Toolkit>>Digital>>Visualization
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,727 Views)
