Converting a string to a time stamp variable
Hi, I found that using the default time stamp (seconds from 1904) for all your data makes things much easier. Simply change the string (seconds) to time stamp with the string to time stamp under timing palet. This creates a time stamp from the string which you can wire into x-y graph. There is a property of the graph which will convert the time stamp into whatever format you want.  Just click on x-axis and go to format precision and click absolute time. It will auto convert
Message 11 of 19
(11,566 Views)
@resrchengee wrote:
...Simply change the string (seconds) to time stamp with the string to time stamp under timing palet....
"string to timestamp"?
Message 12 of 19
(11,558 Views)
Where do you see a "string to time stamp" function on the timing pallette?  The only thing I see is seconds (double) to time stamp (at least in LV8.2).  The thread was based on taking a string such as "8/30/07 11:42 pm" and converting that to a valid timestamp.
Message 13 of 19
(11,555 Views)
ahh my apologies .. I meant string to dbl then dbl to time stamp.
Message 14 of 19
(11,537 Views)
This is really the kind of thing that should be built into LabVIEW, since it's a very common task and its not particularly easy (at least if you want to support a wide range of input).  Excel does a pretty good job with this, but LabVIEW doesn't even try. I encourage you to request it at the project suggestion center.
http://digital.ni.com/applications/psc.nsf/default?OpenForm
Message 15 of 19
(11,526 Views)
That doesn't make any sense either. For this to work, your string would need to be the number of seconds since 1904, not a date time string.
___________________
Try to take over the world!
Message 16 of 19
(11,520 Views)
It is. Since 8.0, the Scan from String function can do the same thing as the VI I posted earlier in the thread.
___________________
Message 17 of 19
(11,519 Views)
A simple solution is the use of datetime.parse(String, IFormatProvider) from .NET Framwork 2.0
So you can select a specific culture (I didn't found that in Labview)
1.  Constructor Node: Assembly mscorlib 2.0.0.0, Object: System.Globalization -> CulturInfo(String name)
Culture/Language Name:
(empty string): Invariant culture
"en-US":  English (United States)
2.  Invoke Node, Assembly  mscorlib 2.0.0.0, Object System -> static Method DateTime.Parse
s:  string containing a date and time to convert.
provider : IFormatProvider from 1.
Message 18 of 19
(10,736 Views)
Thank you Peter for this interesting and comfortable alternative to 'scan from string'. I tested it and it works. Unfortunately it works slow for batch conversioning. I attached a vi where I benchmarked the conversioning routines. I thing this is still a problem between labview typsystem and dot.net CTS.
Message 19 of 19
(10,576 Views)
