Converting VI´s from 6.1 to 6.0.2
Who can convert my VI´s from Labview 6.1 to 6.0.2?
Please answer me and I will send the file directly to you! Thanks!
(2,686 Views)
If you are using 6.1 I believe you can use the "save for previous" in the File>Save with Options... to generate a 6.0.2 version.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,676 Views)
If you had just attached the files you needed the conversion on, it would probably have been done by now. Look below the message body for the attachment button.
(2,674 Views)
