Converting LabVIEW block diagram into flowchart
I need to convert a LabVIEW block diagram(code) into a simple flowchart. The LabVIEW code is rather complicated algorithm to find a true peak from array obtained from an acquisition. I have two VIs(one is calling for a sub-VI). I can attach the VIs if needed.
Can you help?
Thanks.
(2,761 Views)
There is no way to just "convert" a block diagram to a flow chart.
If you understand how the program works then flow charting it should be relatively easy.
BTW: Most programmers make a flowchart of their program before they start programming
=== Engineer Ambiguously ===
(2,745 Views)
Are you requesting this because you have a hard time understanding the LabVIEW code and want someone else to translate it to a simpler flow chart that you can understand better?
Santhosh
Soliton Technologies
(2,730 Views)
I was hoping there is an easy way to reverse-engineer other people "spaghetti" LabVIEW code, but obviously there is no way.
Thanks.
(2,724 Views)
Thanks.
Nope, sorry you are on your own here...
(2,719 Views)
It is easy to reverse-engineer well written LabVIEW code. It often very logically organized and is self-documenting.
Not so much for "spaghetti code". It's like asking to reverse-engineer a plate of spaghetti marinara back into grains of durum wheat and fresh tomatoes.
Still, what might seem like an intractable mess to some, could be quite easy to figure out for a LabVIEW programmer with decades of experience. Feel free to post it.
Also remember that the DFIR step of the LabVIEW compiler itself will internally deconstruct and simplify the diagram into a dependency graph that is much better organized, but that is not something that is exposed to the user. I am always amazed how gigantic and horribly written LabVIEW code still almost instantly compiles into perfectly running machine code. Amazing! 😄
(2,708 Views)
