Converting LV 7 to LV 6.1
Does anybody of you know a way to convert LV7-VI's to LV6.1? I don't need to run them, I want to look at them. I am asking because I started with LV7 but had to change to LV6.1. My "old" VI's are not running anymore.
Arno
Message 1 of 19
(4,213 Views)
You can save your VI into the previous version of LabVIEW by going to File >> Save with options >> Save for previous. Anyway most of VI writing in LV 6.1 can be read and run in LV 7, without any change.
Hope this help
Isabelle Jean
National Instrument
Isabelle
Ingénieur d'applications
National Instruments France
Message 2 of 19
(4,213 Views)
You can convert LabView 7 vi;s to version 6.1.
From the
File menu, select
Save with Options, then select
Save For Previous
However, some new features of version 7.0 will not convert to 6.1
Message 3 of 19
(4,213 Views)
Thanks for your hints, but they all need an INSTALLED version of LabVIEW 7. Do you know a way without installing the new version again?
By the way, I cannot open the new files. If I try the message "VI version (7.0) is newer than LabVIEW version (6.1)."
Arno
Message 4 of 19
(4,213 Views)
You may want to post your vi's on this Discussion forum and someone will probably be glad to convert them.
Message 5 of 19
(4,213 Views)
Here you go ...
It is only one. But one I need very urgently.
Message 6 of 19
(4,213 Views)
see attached file - converted
Message 7 of 19
(4,213 Views)
I wish the same for this program. I hope I dont bother you. thank you
Message 8 of 19
(3,937 Views)
Here you go!
Eli S.
Message 9 of 19
(3,913 Views)
Thank you for your help.
Message 10 of 19
(3,901 Views)
