I have some datalog files from LV5.0 and I'd like to use them in LV6i, but when although I push convert when asked it provides input parameter invalid when reading. I'm using the same vi I used to create and read the in LV5, so it's not supposed to be a program mistake. How can I convert them?
Try using the "Read Datalog File Example.vi" that comes with labview 6i. It uses different subvis than the LV 5 equivalent. If you do this, it should convert the file without any issues.
