Converting Daqassit code
i am trying to change the convert clock of my aquisition board in order to change the interchannel delay.
Once i am new in Labview i just use Daqassist for aqusiition i don't know how to use the daqmxtools.
I read some examples in this forum adn then i tried to the my one vi.
I use normally the Daqassist to generate the channels, i'm measuring 16 voltages. Then i click with the right button of the mouse and chosse the optionOpen fornt panel. Then i tried to put the Damx node timimng but every time i tried to run the VI it said that a bad terminal was unwired.
Can someone help me with this?
The best Regards,
José Teixeira
(3,173 Views)
You will need to wire up whatever required terminal you left unwired. Since you did not postyour code, I have no idea what is unwired.
(3,169 Views)
 Hello Dennis,
the code i have is this.
I am aqcquiring voltage in one channel of a NI 9205 with a CDaq 9172.
Thanks for your help.
The best
(3,147 Views)
What do you want to do? Can you give the configuration of Daqassist?
I advice you to read this document:  Getting Started with NI-DAQmx: Main Page
(3,117 Views)
