Converting C code to labview
As I'm not familiar with C code, can someone please help me convert this function to Labview (8.6)? See attached txt file.
Labview 8.6
(4,790 Views)
Well, you're missing a function call, so no one is going to be able to help you with that.  However, did you search for CRC?  There are tons of samples out there, including one I did here.
(4,771 Views)
Accepted by topic author Gizzmo
Here's a very direct translation.  If you know that the length parameter will be equal to the length of the array, then you don't need the length parameter and you can use an auto-indexing for loop, just trim off the last element if the "create" parameter is true.  (Snippet is LV 2009 but attached VI is saved for 8.6)
(4,758 Views)
Nathand, your solution is working as I would expect.
Thanks to both of you.
(4,711 Views)
is it possible to convert  c code to labview
(4,516 Views)
If you know what is happening in your C code, then it is generally possible to duplicate that same functionality in LabVIEW code.  But that is not the same as "converting".
(4,495 Views)
