Converting Access DB to SQL Server DB using LV Database Toolkit
Hello all:
I am looking to convert an Access database to SQL Server database.  The LV Database Toolkit was used to write to the Access database.  I want to use the LV database toolkit to retrieve the data and write that data into a SQL server format.  Has anybody done this before and are there any "surprises" I may run into?
(4,024 Views)
Found this on MS' website; hope you'll find it useful:
-Khalid
(4,016 Views)
Thanks, I'll start reading...
Robert
(4,000 Views)
