Convert voltage to force
I have a VI that was used with a NI 9237 to display the force from a load cell. The 9237 is no longer working, so I am now using a 9215 (simple analog I/O) with the load cell. I need some help changing the code to convert the voltage output to force (in lbs). Any help would be appreciated as I need to finish up some tests in the next couple days. Thanks!
(2,669 Views)
It looks like reading of the sensor is all wrapped up inside an express VI, what are you having trouble with?
(2,645 Views)
