Convert two numbers to signal
I have some u8, u16 and dbl values, of which one is the time of the sample. how can I convert this values that I can view them in a graph indicator ? I think I have to convert it to a signal, but how can i do this ? Is there a special type cast operation for this ?
regards, tobias
(2,743 Views)
Do you mean you have the Time interval between datapoints??
And, did u try using 'build waveform' function?? look at attached vi
(2,730 Views)
I have some measurement values, which are u8 and u16 values and another u32 value which is the time in milliseconds since the system is running. I get all this data via UDP and parse it. I'd like to display the measurement values over the time, which I get from the UDP-packets.
cheers, Tobias
(2,726 Views)
Hi Tobias,
I would use an XY-graph. Build arrays from your u32-data (x-axis) and u8/u16-data (y-axis). Bundle the x-axis and one of the y-axis arrays to get a plot, use a "build array" node to add several plots for one graph...
(2,716 Views)
