Convert to number
I'm using XBee to communicate with Sparkfun Sensor Stick. I want to display the data on labview. However, it currently looks like this.
How do I convert it into an array of numbers so that I can display them on indicators?
I used String to Byte Array, but it does not work.
Message 1 of 36
(5,877 Views)
Hi make...,
please switch the string display to "HEX display".
Then read the manual for your SensorStick. It should contain a paragraph on the formatting of those data. You NEED TO KNOW the data format before you can convert those data!
Converting string to byte array may be a starting point, but probably you also need to use some typecast here…
Btw. downscaling the snippet graphics seems to remove the embedded LabVIEW code. Either switch off scaling of the snippet or attach the real VI (with some typical data set to default for your "Read Data" string)!
Message 2 of 36
(5,863 Views)
Also, a single byte seems a little low resolution for a measurement value like "gauge".......
Norbert
Norbert
Expert: Geometry
Message 3 of 36
(5,857 Views)
Oh! I've attached the VI.
I'll find out the data format. What do I do with that information then?
Message 4 of 36
(5,846 Views)
Hi make...,
the manual will tell you how to decode your data stream...
Do you expect numbers like these:check.png?
Atleast the first two appear reasonable...
Message 5 of 36
(5,839 Views)
I couldn't find the manual. My sensor stick is connected to an Arduino Pro Mini. Here is the program. Can I use information from this program to figure out how to convert data stream?
I expect the numbers to be pitch, roll, yaw and altitude data.
Message 6 of 36
(5,771 Views)
Hi make…,
I'm not that good in reading C code, but you might find the place, where bufTX[] is filled with data. Then you know how to interprete that message content…
Or ask "Remy DO" who wrote that program!
Message 7 of 36
(5,738 Views)
Hi, what do you mean by "data format"?
Message 8 of 36
(5,689 Views)
When you are working with some device, you need to understand the communication and data format or protocol) i.e. in which format it is sending is appearing. Information like position of data etc
when any device sends any data, for all the inforation it sends the position of data and protocol is fixed, you need to understand it. Find the manual
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 9 of 36
(5,681 Views)
The 3 manuals for the accelerometer, magnetometer and gyros are here.
I think this Sensor Stick uses a I2C protocol.
Message 10 of 36
(5,676 Views)
