Convert string to integer array
I'm reading a packet with TCP Read.  The data out is a string o 248 bytes.  I need to convert that to an array of  62 U32's.  I tried type casting in a loop but that didn't work.
What's the correct way to perform the conversion?
Thanks.
Message 1 of 10
(10,080 Views)
Just typecast to a U32 array. No need to use any type of loop.
Message 2 of 10
(10,073 Views)
there are string convertions uder the string pallette that may help
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 3 of 10
(10,071 Views)
Why would you go through a string?
To original poster: As Dennis indicated, you do not need a loop. Byte endianness may be a problem, though. Do you know what this is for the source data?
Message 4 of 10
(10,069 Views)
I'm using a string because that's what TCP Read's data out is.  Is there some way to change that?
Message 5 of 10
(10,063 Views)
When I simply type casted, all I got was a single value I did not get an array.  I think the single value was simply the first four bytes of the string. That's why I tried a loop.
I think I'm misssing something with type casting.
Message 6 of 10
(10,056 Views)
Accepted by topic author JohnSantaFe
Smercurio_fc is right. I forgot about the endianess. Instead of the type cast, you could use the Unflatten From String. Depends on what is generating the data.
No, the TCP/IP Read output is only a string.
Message 7 of 10
(10,051 Views)
Did you do this:
Message 8 of 10
(10,047 Views)
You definitely did something wrong if the type case did not return an array. Are you sure you have a U32 array wired to the type input?
Message Edited by Dennis Knutson on 09-17-2009 12:24 PM
Message 9 of 10
(10,045 Views)
Ah that's it.  I had wired just an integer to the type for the type cast and not an integer array.
Thanks to everyone for your help.
Message 10 of 10
(10,010 Views)
