Convert labview 8+ to 8
Hello again,may you convert these Homer and Minesweeper to labview 8(my labview 9 evaluation has expired)
(2,967 Views)
Accepted by topic author Frodo Baggins
Hi Frodo,
Here are your VIs. I recommend to you to use projects in the future. Some VIs are not executable now, as I had to remove event structure when saving for previous version - it is known problem Smiley Sad
after you add them and configure tham back, you should be able to run your VIs normaly.
Stefo
(2,934 Views)
