Convert hex number to mac address with colons
This might be a simple thing to do but I can't make it happen 😞
So I need to make a mac address with colons. At first, the Address is  divided in two sections.
First the constant part C87248 and the second part as a running number from 0 to appr. 16000000
The outcome should look like this C8:72:48:00:00:00
The .vi is going to be used in teststand 3.5.
The running number is an input parameter and .vi should return the mac address as a string so that teststand could read it.
These hex conversions in labview drives me crazy. I'm able to convert the address to format
C872 4800 0000 but I can't reformat it the way i want it.
(8,318 Views)
Hi sebulban,
  Please tell me whether the Hex address is a string or an integer...How it is stored in testStand variables?
Thanks and regards,
srikrishna
Srikrishna
(8,313 Views)
Accepted by topic author sebulban
This should do it, although it's probably not the most efficient way.
MC
(8,302 Views)
Thanks ! That works just fine 🙂
(8,290 Views)
Omar
(8,276 Views)
And here is yet another solution.
Note: Right click on the Search And Replace function and check Regular Expression.
Edit: Added the 6 constant to length input of number to hex
LabVIEW 2012
(8,267 Views)
Speed is probably not important for something like this. But out of curiosity I did a comparison of all three techniques above. I ran the algorithms 10M times each.
MaxCrunch 250mS
Omar II 1586mS
SteveChandler 1590mS
Altenbach: <46pS (Only he has not yet posted his version Smiley Very Happy)
LabVIEW 2012
(8,257 Views)
