Convert float to interger
Stupid question but I can't find the anwser. Where is the function that allows meto convert a float number to a string?
Thank you.
(3,796 Views)
Accepted by topic author RaphaelMT
Your title says convert to an integer, your post says convert to a string. For an integer use the "To Long Integer" (or whichever kind of integer you want). For a string use "Number to fractional string". Both of these can be found by pressing "ctrl + space" and typing their name into the quick drop window.
(3,779 Views)
By the way, "format into string" becomes very useful when you want to create a string with a couple pieces of data or other characters in there.
(3,777 Views)
