Convert float string to 32-bit Hex
Hi: - I’m hoping someone can help.
I have a string containing a float number “3.5266287875071523e-38”
I need to convert this to a 32 bit HEX string.  From http://babbage.cs.qc.edu/IEEE-754/ I know the correct answer is 0x”01400208”.
I can easily get the 64-bit answer (3828 0041 0000 0000)
I’ve searched and searched the web - I tried many different approaches – all without success.  The closest I've been able to get is the attached VI.  I think I’m missing a nugget of knowledge.
Thanx to whomever can take some time and get me un-stuck
(5,458 Views)
Accepted by topic author Mr_Monday
Hi Monday,
try this one:
Remember: SGL datatype uses 32 bits...
(5,451 Views)
Just wire a SGL constant to the Default input of Fract/exp String to number.
(that will give you a 32 bit IEEE-754 represttation- and then when the SGL is flattened you get
"Should be" isn't "Is" -Jay
(5,449 Views)
Thanx guys - both of you:  BOTH solutions are good - either let the stringToNumber conversion create the single or convert it after the fact.  As GerdW points out, the nugget I was missing was that SGL are 32 bit.  I appreciate your time
I won't admit to how long I tried to solve this and embarrased to find that the answer is so straightforward <blush>
(5,439 Views)
