Convert dynamic data to single scaler
I want to convert dyanmic data to single scaler, however, the amplitude of the output is always smaller than the input signal.
Does any know why? thanks!!!!!!!!!!!!=)
plz see the attachment.
Message 1 of 11
(3,949 Views)
    Can you save the vi at older version?, i have 2009.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 2 of 11
(3,944 Views)
Hi Luis,
I save it to version 8.6.=)
Message 3 of 11
(3,939 Views)
Not sure what you mean by 'smaller'. With the evil dynamic data type, the conversion takes the last element in the Y array. What are you expecting?
Message 4 of 11
(3,932 Views)
Hi nozombie,
      I cannt run your vi, i dont have someones .vi, but i run a similar test and both signals look equals.
      Can you post a print screen and explain a little more where is the difference?
Best Regards,
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 5 of 11
(3,930 Views)
Hi Dennis,
If you run the vi i attached, you can see that the bottom right graph on the front panel has an amplitude of 0.75 instead of 1. However, my original input signal has an amplitude of 1.=)
Ivy
Message 6 of 11
(3,926 Views)
Hi Luis,
Thank you for ur reply 😃
As u can see from the picture, i use a simulate signal as the input(sine wave with an amplitude of 1). First i feed the signal into a downsampler function. The output is waveform data type. Then I convert it to dynamic data type and then to single scalers. However, after i convert it to single scaler, the amplitude of the signal changes to be 0.75 instead of 1. That's the problem 😃
Ivy
Message 7 of 11
(3,924 Views)
I can't run your code due to missing VIs, but could it be the data is being converted?  I don't think it's being converted to RMS voltage, since your measurement is too high, but it could be related to something similar.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 8 of 11
(3,919 Views)
I can't run it either and since you did not save the front panel with typical data, there is nothing to actually look at. Again, I'll ask what do you expect to get from the conversion to a scalar when you have an array of values?
Message 9 of 11
(3,913 Views)
Hi nozombie,
        What downsampler parameters are you using? Why a downsampler and not a decimate function? I think if you downsample much, you can lost someone peak values.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 10 of 11
(3,911 Views)
