Convert dynamic data to a cluster of 4 elements
I'm trying to connect the acquire signal vi to a signal generation vi. The acquire signal is dynamic data and how could I convert it to a cluster of 4 elements which would connect to the signal generation. If I can't do that, then is there a way around it.
Moe
(2,858 Views)
Could you be a little more specific and name the actual signal gneration function you are trying to use? Posting the code you are having trouble with would be even better.
(2,851 Views)
