Convert digital waveform into square waveform with N Samples.
I'm trying to convert this digital waveform into square wave for analog output model.
(Result converted by [Digital to Analog.vi])
But this VI seems ignore the sample rate information here.
I get ramp instead of square wave(graph at Top-Right corner).
Is there a vi can convert such digital waveform into square waveform with corresponding sample rate?
Thanks!
(2,583 Views)
Why don't you attach your actual VI so we can see what is going on in the block diagram.
Perhaps what you did is almost correct, but we can't debug a picture of a front panel.
(2,539 Views)
Sorry,
This is the VI i was testing.
The reason i tried this method(from digital pattern to square wave) is that i can't figure out how to form a 000 to 101 pattern with square wave signals.
(2,523 Views)
