Convert decimal number to Binary represented ??
I have a decimal number in the diagram, how can i show this number as a
"Binary" on the panel ?
Thanks !
(3,615 Views)
I suppose it is an integer decimal? Just create an numeric indicator, set it's
representation to one of the integer types (right-click on it, select
'representation'),
then set it's Format to binary (right-click, select 'Format&Precision', select
'binary' in the Format drop down list)
If you make the 'Radix' visible (right-click, 'Visible items-->Radix) the
display
format can also be changed at run-time by the user (left clicking on the Radix
indicator)
-Franz
company schrieb:
> Hi,
> Thanks !
Franz Josef Ahlers
Section Semiconductor Devices
Physikalisch-Technische Bundesanstalt
Bundesallee 100
D-38116 Braunschweig
phone: (+49) 531 592 2410
fax
: (+49) 531 592 2405
(3,615 Views)
