Convert a hex string to the same hex number
I Need to convert the hex string "00601D248001" to the hex number 00 60 1D 24 80 01. Once it is hex I plan to insert the hex values into a string and save them into a file.
Thanks in advance for any assistance
Lonnie
(3,200 Views)
Getting each hex value can be done by converting 2 characters to a number (strings command).
Of course you need to be sure that the number of characters is even. Else, you have to test for that first.
However, if you need your result (as you post it) as a string, it might be easier just to insert the spaces.
(3,200 Views)
See below example :
(3,200 Views)
