Convert a Decimal Numeric to Hex String of 2 BYTES
Hi Nayan,
could you please attach your Vi in LV2011 again?
For your question: Do you replace array subsets or do you build an array by appending new elements?
Message 11 of 20
(2,230 Views)
Here is the converted vi.
Message 12 of 20
(2,227 Views)
Hi Nayan,
you insert new elements in your array at Index zero using InsertIntoArray function. And now you wonder why each call of your VI inserts a new element? Really?
Did you read the help for that function?
When you want to replace elements at certain indices of your array you need to define an array with those elements and use ReplaceArrayElements!
Message 13 of 20
(2,224 Views)
Thax.
I tried 'Replace Array subset' function, but problem here was if I have an emplty array, it will not accept the value.
Is there any option that even if the array is empty it should replace the value what I wanted??
Message 14 of 20
(2,221 Views)
Hi Nayan,
when the array is empty then there is no element you can replace. Sounds ok for me!
As I said before: you need to define an array with some elements. Or you need to implement some logic to append new elements when the y don't exist before…
Message 15 of 20
(2,216 Views)
How you will get the index for Empty array to replace your data ?
If you know your size of your array then 1st build array & replace your indices. If you don’t know about array size then check array and index.
If array is empty/index value is out of your array size then just add that element to array (using Build array) else replace  same as you mentioned.
Munna
Message 16 of 20
(2,216 Views)
Thanks to both of you.
I have 2965 elements in the array, so created it first and now will use Replace Array Subset function.
Message 17 of 20
(2,205 Views)
If your replacing data continuously in a loop then use Shift registers to pass your data else you will get Array with Last updated Index.
Munna
Message 18 of 20
(2,199 Views)
I am not replacing the data continuously in a loop here, but thanx for the valuable suggestion.
Message 19 of 20
(2,192 Views)
Please show your latest code. Your earlier VI made no sense at all.
Message 20 of 20
(2,163 Views)
