Convert a 1D array of cluster of 2 elements to a 2D array of double?
Hi there,
as the question says:
How to convert a
Using Labview 8.6
thx
(12,621 Views)
what is the content of this 1D array of cluster?
  If it is juts a decimal string you can use this snippet
Regards
Guru (CLA)
(12,613 Views)
content of 1d array of cluster of 2 elements is double double
if I use your unbundle by name to connect to decimal string to number I get: source is void : sink is string
Message Edited by isa-jena on 04-01-2010 06:02 AM
(12,605 Views)
Accepted by topic author isa-jena
Use "Cluster to Array" in a for loop.
See image.
Hope this helps.
(12,596 Views)
thanks a lot
(12,587 Views)
