Convert Time Stamp to String
What is the most efficienct way to convert a Time Stamp Control to a MM/DD/YYYY string? I am going to use its output as date parameters to a WHERE clause to a SQL Server query.
(13,362 Views)
Accepted by topic author Eric1977
Format Date/Time String is a simple option.
(13,358 Views)
I skipped right by that. I must not have had enough coffee yet this morning. Smiley Very Happy
Thank you.
(13,345 Views)
You're welcome Smiley Happy
(13,342 Views)
Those format codes can be tricky to write from scratch. I usually format a timestamp constant the way I want it displayed, switch to advanced format editing and copy the format string.
"Should be" isn't "Is" -Jay
(13,341 Views)
Jeff,
I just did it like this. Do you forsee any problems? I noticed yours had the greater than and less than math operators near the beginning and end of the format string.
(13,336 Views)
@Eric1977 wrote:
Jeff,
Well, what is the output? Do you foresee a problem? The LabVIEW Help is quite clear on the format. The very first sentence of the Help file for the Format Date Time String provide a link to the codes: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/string/format-codes-for-the-time-fo...
(13,333 Views)
