Convert String to Number
I met some problems when I tried to convert a string to a floating point
number. I used Fract/Exp String To Number, but didn't get the desired
output.For example,
String: 1.2345, the Fract/Exp String To Number gives 1.23 but not 1.2345.
Can someone assist? Thank you.
Ju, Jian
(3,408 Views)
Use Functions->String->Scan from String instead.
2006 Ultimate LabVIEW G-eek.
(3,408 Views)
Did you set your front panel indicator to display more than 2 digits of precision? Right click on the indicator and select Format & Precision to change it.
(3,408 Views)
