Convert String into variable length Float Array (Dynamic Arrays)
I am trying to convert a user input string (list of numbers) to an array of however many numbers there are in the list. But I can only make this work with a fixed number of floats that the build array expects. Is there any VI or method to dynamically create an array from a sting list of numbers. Simplicity is the key, would not be worth it for this project if it involves much complexity.
The VI I am working on is attached. I searched the forum, and the most relevant thread is linked below, though the VI they posted did not run on my version of LABVIEW. I am running LABVIEW 2011, SP1.
http://forums.ni.com/t5/LabVIEW/Convert-1D-string-Array-to-Numeric-Array/td-p/50711
Thanks in advance for your advice/help.
*elA
(3,425 Views)
Much easier with Spreadsheet String to Array:
(3,421 Views)
