Convert String from ASCII to ANSI
a command line instruction via LabVIEW function "System Exec.vi" retrieves me a string in ASCII format. Is there a function to convert string from ASCII to ANSII format? I use LabVIEW 8.5 German Installation.
Kind Regards
Christian
Christian
Test Engineering
digades GmbH
www.digades.com
(3,368 Views)
Hallo Christian,
AFAIK there is no such in function in LabView...
But you can:
- use "Search and replace string" to search for ASCII chars and replace them by their corresponding ANSI char, do this in a loop for all chars to be replaced (acceptable speed for small strings...)
- convert the string to an U8 array and use a lookup table to convert all bytes from ASCII to ANSI, convert back to string (may be faster for long strings...)
(3,363 Views)
