Convert Seconds to Hours:Minutes:Seconds
@Wayne.C wrote:
Altenbach already did it the absolute simplest way to do it.  Format an Integer indicator to display time.
I added that just as a bonus, because the question was not entirely clear. 😄 Yes, I actually had it first as a DBL, but the original question was talking about integers, so I adapted it.
It does not deal with the second (no pun :D) part of the problem:
"If it is possible to do the above, then how can I seperate it into 00 Hours indicator, 02 Minutes indicator and 03 Seconds indicator?"
And that's why I added the solution where we get three array elements. If that's still not "seperate" enough, an "index array" will probably help. 😄
Message 11 of 23
(9,714 Views)
Of course a pure math solution such as P@Anand's above can also be "simplified", and that's probably what I would use (bottom of code):
(EDIT: corrected label mixup. Thanks crossrulz)
Message 12 of 23
(9,707 Views)
...except what you labeled at hours is really minutes and minutes and really hours for the "pure math" version.
Message 13 of 23
(9,700 Views)
Yes, modify as needed. I will correct it later. Sorry about that. (It is correct here already...) 😄
Message 14 of 23
(9,694 Views)
this one also works 🙂
Message 15 of 23
(9,586 Views)
Actually, shalins, your VI does not work. Put in 123 seconds and see what you get. You need to lose the last "Quotient&Remainder". Wire the remainder from minutes directly into the format string for seconds.
Message 16 of 23
(9,581 Views)
No, it does not work!! No matter what the input is, the "seconds" is always zero. Please check your work first. (the fix is easy, simply remove some code. 😉 Try it!)
(It is also about orders of magnitude more complicated than the above solutions and peppered with coercion dots. So what's the point?).
In additions, please stick to normal characters in filenames. Windows cannot deal with your file unless I rename it first.
Message 17 of 23
(9,575 Views)
yes....I've fixed it 😉 thnx
Message 18 of 23
(9,559 Views)
I have a question similar to the forum so I decided to post here. I am also wanting to convert seconds to minutes, but I am using an array that shows me lap times that are accumulating. Can I apply the same type of solutions shown here to get an output in HR:MIN:SEC?
This is an example program I found, and am trying to alter for practice.
I attached a portion of the VI for clarification.
Message 19 of 23
(9,494 Views)
Late reply IUPUI, but you can use the same ideas. The easiest is to change the indicators format to show time.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 20 of 23
(9,475 Views)
