Convert Labview 5 VI into Labview 8.6
I currently have Labview 8.6 and I cannot open up a VI  because it was saved in Labview 5.
How do i convert it to 8.6? Attached are the VIs.
Message 1 of 46
(7,457 Views)
It is looking for "HP70200 Read Peaks.vi".
I suspect you need to have the driver installed.  I will try to convert without it.
Message 2 of 46
(7,436 Views)
Here it is in LabVIEW 8.5.
You should be able to open it.
Message 3 of 46
(7,435 Views)
Thanks for the help!
The .llb file still has some VIs associated with it that are still in the old format.
Can you help me there?
Message 4 of 46
(7,416 Views)
Sure.
Can you provide the missing VI that I mentionned way above?
R
Message 5 of 46
(7,408 Views)
Hi, I also have a problem about the labview vision. I need some VIs saved by labview 5.0, and now I want to open them by labview 8.5.
Could do please help me to transfer them?
Thanks a million.
Message 6 of 46
(7,376 Views)
and also the following VIs
Regards
Message 7 of 46
(7,374 Views)
working on it
Message 8 of 46
(7,365 Views)
Here they are:
Message 9 of 46
(7,364 Views)
Message 10 of 46
(7,363 Views)
