Convert LabVIEW NXG Project to LabVIEW 2018
Hi everyone,
I have created a Project in LabVIEW NXG and would like to convert it to LabVIEW 2018. Are there any possibilities to do so?
If it is not possible to convert the whole project, is there at least a way to convert the VIs?
So far I have only found informations about how to convert from 2018 to NXG or from 2018 to older versions...
Thank you very much,
Jonathan
(2,896 Views)
@jonathanbe wrote:
Hi everyone,
Jonathan
No there is not.  You'll have to rewrite your code in LabVIEW 2018 using the NXG code as a guide.
Why do you want to switch?  What caused you to start in NXG and now migrate your code from it?
(2,866 Views)
Thank you,
I already found the corresponding knowledge site here.
I think we will have to use NXG.
(2,858 Views)
@jonathanbe wrote:
Thank you,
Be careful about going down too far down the NXG path, as you may corner yourself by needing a feature that isn't yet available.  My NXG takeaway is that it's not quite ready for prime time yet.
Bill
CLD
(Mid-Level minion.)
(2,837 Views)
