Convert IVI instrument address name to VISA
Hi all, i have developed code for 2 different series spectrum analyzers.  One of which uses IVI for its address and the other VISA.  I have the 2 different programs in a case structure where the user initially selects which instrument is being used.  This choice is the case selector.  The problem i have is with the addresses.  I cannot wire the IVI address ctl line from one case into the VISA address inputof the other case.  The address number is the same.  Id there a way to convert?
Grant
(4,274 Views)
Hi all, i have used to variant and then variant to data.
Please ignore.
(4,270 Views)
Hi all, even though an error was not seen on the block diagram when inserting the convert to variant and then variant to data option, i have now discovered that during execution an error is seen: "LabVIEW:  The data type of the variant is not compatible with the data type wired to the type input."
Any ideas of converting a IVI instrument address to VISA address?
Grant
(4,252 Views)
Hi all, any updates on this problem?
(3,981 Views)
Hi all, i have created a solution for this.  This may come in handy for someone so i have attached my subvi.
IVI-VISA
Regards
(3,971 Views)
