Convert Hex String to Signed Int
Hey,
I was wondering if there was a way to convert a string to integer. Now here's the problem, the string is actually hex characters so in normal view I see my hex characters. I attached a screenshot of my normal string indicator. What I want to do is take those 4 characters and make a signed 32 bit integer. Thoughts?
(5,071 Views)
Accepted by topic author Gus67
You can do it with the Scan from String function:
This would output "27".
If someone helped you out, please select their post as the solution and/or give them Kudos!
(5,066 Views)
Thanks that worked.
(5,059 Views)
