Convert Complex (Pink) Cluster to Byte Array
OP mentioned the arrays should not be prepended by Array size. There's a flag for that in unflatten. Would that help?
Qestit Systems
Certified-LabVIEW-Developer
Message 21 of 23
(848 Views)
 From my first post:
"Flatten to string (and then convert String to U8 array). - This prepends the size of arrays inside the cluster into the byte array, even with the Prepend Array or String Size set to False, since this selector applies only to the cluster as a whole."
Message 22 of 23
(825 Views)
Ah, if you want that, you should just cut out the middleman and use this library/wrapper for the LV Memory Manager that let's you do C-style pointer operations.
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
Message 23 of 23
(820 Views)
