Convert (0,1) values to Boolean
The conversion Boolean to (0,1) does exist.
What about inverse conversion, i.e. (0,1) to Boolean.
Actually I'm trying to convert Sign function output (-1, 0, 1) to Boolean.
With ABS function I can reduce (-1, 0, 1) to (0, 1), but then ... how to proceed ?
Message 1 of 12
(35,898 Views)
Ok, the solution is quite simple - equal comparator.
Sorry for this post
Message 2 of 12
(35,892 Views)
Be careful if using equality floating point numbers - what might appear to be 1, might not actually be 1 depending on how the number is represented in floating point (e.g. it might be 1.00000000000000000000001) and so an Equals? would be false.
Just something to bear in mind - if you're using integers then this isn't a problem.
(blog)
Message 3 of 12
(35,883 Views)
Thanks Sam,
Sign function has 15-bit precision, I think for my case it will be sufficient.
At other side the problem revealed  a little bit more complicated, i.e. (-1, 0, 1) to boolean - using ABS just converts -1 to 1, wheras I want -1 and 0 --> FALSE, 1 --> TRUE
Message 4 of 12
(35,878 Views)
Here is a solution
Message 5 of 12
(35,873 Views)
Just use something like this:
As for your 'other side the problem' - just use a simple select/case structure to get the appropriate value out. Post your code because it sounds like you're over-complicating things.
(blog)
Message 6 of 12
(35,869 Views)
Thanks Sam,
It seems that I've found a solution (post above).
Quite simple, isn't it ?
Message 7 of 12
(35,864 Views)
The exact inverse is Not Equal To Zero.  It will take even give a TRUE value for your -1 case as well.
Message 8 of 12
(35,850 Views)
For my case the truth table is as follows:
-1, 0 => FALSE
1 => TRUE
I think the solution using increment (as it's shown above) isn't so bad.
Message 9 of 12
(35,830 Views)
Accepted by topic author Pavel_47
Hi Pavel,
in this case a ">0" comparison is simpler/"better" than your "+1" "solution"…
Message 10 of 12
(35,824 Views)
