Conversion string for numerical
I would like to take advantage of the data entered by the user in other places for internal calculations, I am using a string and would like to transform it into numbers to be able to use the 3 data entered separately.parametros para o arduino.PNG
(2,502 Views)
You need to give us more information..
Are you trying to convert a string with some sort of delimiter to a numeric array? Is there something keeping you from creating a numerical array itself as a front panel control?
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(2,501 Views)
