Controls lose data binding when added to cluster
Please forgive me if this is a newbie question, but I can't seem to find an answer.
In a nutshell, I have an array (constant) of strings and a cluster of booleans.  I want to search the name of each boolean in the cluster for a match to a string in the array and perform an action for each match.  Say I want to turn on all booleans that match.
The problem is that the booleans are bound by datasocket - to OPC server to PLC.  So when I add a boolean to the cluster, the data binding is dropped.  Attempts to reassign data binding are unsuccessful.  If I move the control outside the cluster and reassign data binding, it works.  There are a fair number of booleans so I want to avoid wiring them one by one.
I am using LabVIEW 8.6 and there is a known bug similar to this for arrays of fixed size.  However I don't totally understand the solution and how I would apply it to a cluster:  "Uncheck autopreallocate arrays and strings in the VI properties execution category for all VIs not intended to run on an FPGA."  There is no listing for clusters.  Could I be doing something wrong?  Should I be using shared variables instead of data binding?
3OLE2573
Return
DataSocket and Fixed Size Array Do Not Work
You cannot use front panel DataSocket data binding with fixed-sized arrays.
Workaround: Uncheck autopreallocate arrays and strings in the VI properties execution category for all VIs not intended to run on an FPGA.
Message Edited by Katelyn on 08-18-2009 12:14 PM
Message 1 of 1
(2,766 Views)
