Controlling the window position on screen when using the Prompt User Express VI
How can I change the window position on the screen when using a Prompt User Express VI.
I have opened the front panel and converted to a standard sub vi then created a property node.
I tried changing the position top and position left, but no change occurred.
(3,064 Views)
Did you also go to VI Properties>Window Appearance>Customize and uncheck the Auto-Center option?
(3,057 Views)
I did try removing the auto-center from the VI properties. I can move the buttons
to different locations but not the window that contains the message and buttons.
It allways pops up in the middle of the screen when running the VI.
(3,038 Views)
How are you setting the position? Why don't you post the VI or an image of the block diagram? I simply changed the property, moved the VI to a new location, and saved the VI. When I run it, it pops up in the last location that I had placed it.
(3,031 Views)
