Controlling the STDIN STDOUT of a legacy application in LabVIEW
D:\Projects\OpenG\opengtoolkit\pipe\source\ogpipes.*
Error msg
DLL is searching for this path.
where the DLL will be there?
Message 11 of 12
(209 Views)
This does not sound like the standard search location. Normally the OpenG Toolkits are installed inside the according LabVIEW directory (<LabVIEW>/user.lib/_OpenG/ogpipe, since they will tend to be LabVIEW version specific after being loaded in a specific LabVIEW version.
Another complication is likely that you are probably using 64-bit LabVIEW. The OpenG Pipe library in this thread has not been recompiled to also provide a 64-bit version of that DLL. Unfortunately it is not just a simple recompilation in Visual Studio and a package rebuild but a bit more involved, since VIPM has no built in support for bitness specific binary artifacts in a package.
I'll check if I can do a new rebuild with proper 64-bit support. But it will take a few days.
Rolf Kalbermatter  My Blog
Message 12 of 12
(197 Views)
