Controlling pressure regulator with labview
I want to know if there is a way to control a digital air pressure regulator (such as festo's vppm led) by increasing/decreasing its voltage. I know that this i can do it with the use of a PLC but I would like to do it with labview and arduino as an A/D converter.
Thank you in advance
Message 1 of 13
(6,153 Views)
Hi bill,
Yes.
We use those VPPM valves in our testbenches, too.
(It doesn't matter which device is generating the voltage signal, PLC or NI-DAQ.)
AFAIK the Arduino will only output upto 5V. The VPPM expects a voltage signal range of 0V - 10V.
We use NI DAQ hardware…
Message 2 of 13
(6,133 Views)
Thanks for you reply,
I know that the arduino can output only up to 5V, but using a relay for example 5-10V  i can work with 10 V. Am I right ?
Message 3 of 13
(6,123 Views)
With relay it should be quite possible.
Message 4 of 13
(6,105 Views)
Accepted by topic author canye23
Hi bill,
The VPPM valves expect an analogue input signal.
With a relay you can create a digital (on/off) signal.
I don't know if this is sufficient for your requirements - for my testbench requirements I use DAQ hardware with ±10V output range…
What about using a simple OpAmp to amplify the Arduino output voltage with a gain of 2?
Message 5 of 13
(6,100 Views)
Relay allows you to do only ON/OF... so only two output available.
Use the PWM instead... but you will need a transistor instead with a power supply to the desired voltage.
Benoit
Message 6 of 13
(6,099 Views)
So with the OpAmp I can amplify the Arduino's output voltage to 10V. So then I want to increase/decrease this output voltage from 0 to 10V using LabView. I think that this is possible.
Message 7 of 13
(6,090 Views)
Yes it is possible.
Benoit
Message 8 of 13
(6,083 Views)
With the arduino you will use the PWM... no need to have OAMP, but instead a transistor and preferably opto-coupler will be better.
Benoit
Message 9 of 13
(6,075 Views)
Hello ,
I have managed to do it by constructing a simple DAC and then by amplifying the signal with gain 2. Of course I lose in resolution but I guess that is the price I have to pay with arduino’s output.
Thank you you all for your useful ideas
Message 10 of 13
(6,048 Views)
