Controlling condensing temperature by controlling opening valve
I modified the code, and it works but I need to determine the gains because I just assumed them
Message 11 of 22
(897 Views)
Hi alhabeeb,
It looks much better now.
You should add a small wait inside the loop and limit the output range of the PID.
Yes. See my comment on step responses above...
You could also try to determine PID gains from analyzing your system:
  • heat capacity and massflow of the hot fluid
  • heat exchange rate and (thermal) delays in the cooler
  • input temperature and (max) massflow of tap water
After all it's a "simple" physical system! 😉
Message 12 of 22
(893 Views)
@GerdW  a écrit :
Hi alhabeeb,
Should I use case structure to add limits to PID?
Message 13 of 22
(888 Views)
Hi alhabeeb,
No, you should read the LabVIEW help for the PID function…
Message 14 of 22
(884 Views)
@GerdW  a écrit :
Hi alhabeeb,
Ohh, Yes it is very straightforward.
Message 15 of 22
(879 Views)
@GerdW  a écrit :
To determine the PID gains you can do some step-response tests and apply the common rules on the step response measurements.
Thanks for all your support. I'm new to use Labview, and I know a little about the control. Would you give me more details about how to determine the gains?
Baqer
Message 16 of 22
(815 Views)
Hi alhabeeb,
Have you tried to search for manuals (using your favorite web search) on your own? "Searching for relevant information" is basic knowledge for engineers!
I found this article easily…
Message 17 of 22
(809 Views)
I used this, and it worked with my system.
Message 18 of 22
(802 Views)
Hi alhabeeb,
So you implemented a plain P-controller!?
This is (in my experience) VERY unusual for a thermodynamic system, involving heat exchangers with massflow-dependent properties!
Message 19 of 22
(800 Views)
Right now my test bench is not completed, so I just attached a thermocouple on the tap water pipe to represents the (T_f_out) and run the VI. When  the T_f_out greter than the setpoint the valve opens and when it is lower the valve close. If the T_f_out high greter than the setpoint, the valve is full open.
Message 20 of 22
(796 Views)
