Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Controlling bechoff IPC using a local labview application
I am using a Beckhoff CX1000 IPC to interface between an AB PLC(via device net) and a device(via rs232. The IPC is running windows CE.net and currently the software is developed usind twincat. I had developed a test program using labview and ideally would like to run my app on the IPC. The IPC has flash card storage. I know beckhoff have made available a active x control however i know nothing of developing this on an IPC. Any ideas would be great
Message 1 of 1
(3,824 Views)
