Controlling a progress bar with a timer
It seems that you used two instances of the slider.
On my picture, I used local variable, which points to one control.
I cannot remember if LV7 has local variable.
Try right click on the control and create>local variable, and then connect the local variable.
The local variable can be set as read or write.
Message 11 of 21
(2,380 Views)
You have two different slide indicators, one called "Slide" the other "Slide 3".  Replace Slide 3 with a local variable of Slide.
Message 12 of 21
(2,379 Views)
Thanks!! Thats done it!
can i ask why you need to create it as a local variable and not how i had done it before? is it because it is being used twice in the same method?
Message 13 of 21
(2,364 Views)
A given control can only have one terminal.  You duplicated your control and it had its own terminal.  You were writing to Slide in the first loop, but writing to a different indicator (Slide3) in the second loop.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(PS:  "I" used as a word should be capitalized.)
Message 14 of 21
(2,362 Views)
Thanks!!
Message 15 of 21
(2,357 Views)
Could you please explain this method?
Message 16 of 21
(2,320 Views)
Explain what method?
Message 17 of 21
(2,316 Views)
i do apologise. The method by
Message 18 of 21
(2,310 Views)
Hi
I am relatively new to LabVIEW.
Is it possible to control fill/progress bar using live timer?
 As in my live clock is running in the background and if the current time is 11:00AM, my progress bar should start filling at 11:20 AM for 10 minutes .
Message 19 of 21
(2,059 Views)
There's nothing to do with 11:00am.
Just do a comparison, if the clock is 11:20am, run a 6000 iteration loop with 100ms wait in the middle and wire the iteration to the progress bar. Also set the progress bar max to 5999.
If you want it to be stoppable, use a conditioned for loop.
Message 20 of 21
(2,055 Views)
