Controlling Valve Using DAQ and 2N2222
Hello everyone, Hope You are good.
I am Using 6008 NI DAQ To Control 24v valve to switch on/off
When I connect the digital pin from the DAQ Directly to the base of the transistor The valve goes on .. and i can't control it
so my question is what is the right connection Should i use on 6008 NI to control the valve
and do i need resistance between the pin and the base .. and if the answer if yes what  is the value of the resistance should i use?
(3,409 Views)
Your question isn't a LabVIEW question, but rather an Electronics Circuit question, what circuit (presumably a 1-transistor circuit) should you use to get a TTL signal to drive a 24v relay.  Maybe "Ask Google"?
(3,338 Views)
For questions specific to the NI USB-6008 you can check out the device's User Guide or Device Specifications, which has the device pinout on the last page.
Francine P.
Applications Engineering
(3,321 Views)
This might be of some help. https://www.electronics-tutorials.ws/blog/relay-switch-circuit.html
=== Engineer Ambiguously ===
(3,306 Views)
