Controlling Micro-controller using Labview
@User002 wrote:
yes i changed the VI by looking at the  @crossrulz`s video but the result is same. Can you please tell me what is the problem?
Honestly not without the device you are communicating with. I gather you programmed the microcontroller?
=== Engineer Ambiguously ===
Message 21 of 27
(2,608 Views)
yes im sending command to the micro controller and receiving output back from it and no i did not send send a \n or \r at the end of data string.Do i have to use both \n or \r or any single?
Message 22 of 27
(2,620 Views)
Well your termination character your microcontroller is sending has to match what your LabVIEW program is expecting or your LabVIEW program has to expect what your microcontroller is sending...
The default is a single Carriage Return.
Message 23 of 27
(2,616 Views)
yes im sending command to the already programmed  micro controller and receiving output back from it which is working fine with putty (sending command and receiving exact output which i need ) and no i did not send send a \n or \r at the end of data string.
Message 24 of 27
(2,614 Views)
And it's more than just putting  \ before an n or r it has to be the proper ASCII character
Message 25 of 27
(2,611 Views)
yes those are ascii chars. I will try with \n and  \r and i will get back
Message 26 of 27
(2,584 Views)
hi everyone,
the problem solved. i inserted delay before read and also in delay in while loop because i was reading too fast.
Thank you
Message 27 of 27
(2,559 Views)
