Controlling KE2000 with LV7.1
Hi there,
I'd like to do some simple measurements with a Keithley 2000 DMM
through LabView over Serial Port and Im even stuck with this simple
task. I played around with the VISA-Controls and even got some
measurements as I wanted to, however, I get (seemingly) random
timeouts. I tried the sample Programm form the Keithly Website
(VisaReadWrite) and first it worked, and now it's stuck, too. The odd
thing is, that first, the timeout was at the Visa-Read step, and a
little later (after various tries without changing anything) I get a
Timeout at the Write-Step. The Device itself does not show any errors,
turning it off and on again does not working, neither does restarting
LV.
Maybe I just locked up the VISA-Session or something? Any Help would be
appreciated!
Dave
(3,242 Views)
Mmmm, I use the Keithley KE2001s all the time but with GPIB.  VISA communications can be quirky and confusing at times.  Although I'm not very familiar with the serial versions I might be able to give you some insight if you post your code.  Without seeing your code I would suspect that there is still some data in the serial buffer causing the timeouts.
K
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,238 Views)
I have used the serial with the keithly and always had quirky little problems like this then i switched to GPIB and never had a problem.
post your code so that we may have a look. I think I still have that meter around here somewhere. Maybe I can try it out here for you.
Joe.
"NOTHING IS EVER EASY"
(3,233 Views)
You should also evaluate using the Keithley 2000 certified LabVIEW driver available on NI's Instrument Driver Network (ni.com/idnet).  You can either use it directly or as an example for how to program the instrument yourself.
(3,226 Views)
Dave,
I have also had RS232 issues with the KE2000 and another Data Acquisition program (CEC TestPoint).  They went away when I dropped the baud rate from 19.2K to 9600.
I don't know if that will help with LV7.1, but it's worth a try.
Mike
(3,220 Views)
