Controlling Digital Camera using a SDK
For an application I am using two Canon PowerShot SX 110IS cameras. I need to control the camera parameters (Zoom. Click, focus, macro on etc) form LabVIEW. I have SDK which is supplied by Canon. Can any one help me out in this regard? I will be more thankful if you share example code.
Thanks in advance,
Adarsh
Adarsh
CLA - Certified LabVIEW
Architect
https://www.youracclaim.com/badges/4871da75-1b8b-422a-a881-9ab206d2d36d/public_url
Message 1 of 12
(5,539 Views)
Hi Adarsh,
what contains the supplied SDK? Do you have a dll or an activeX interface?
Mike
Message 2 of 12
(5,537 Views)
Thank you for reply 🙂
SDK contains dlls(PRSDK.dll and PSLIB.dll).
Adarsh
Adarsh
Architect
Message 3 of 12
(5,534 Views)
Hi Adarsh,
try controlling the Camera with Active controls or DLL`s supplied from vendor.
Also make sure that the camera is supported for remote capture feature,
since some canon camera`s with digic 3 processor does not support this.
Also try this link and use this DLL . I have tried this with my application some
time back . It works but without registration of this app the operation isn't very smooth.
http://www.steves-digicams.com/digsoftware_cameractrl.html
Sundar.
Message 4 of 12
(5,527 Views)
I am waiting for your help
Adarsh
Adarsh
Architect
Message 5 of 12
(5,506 Views)
Hi Adarsh,
do you have a description for your dll files? You can use the "call library function node" to call the exported functions of the dll.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/call-library-function-node.html
Mike
Message 6 of 12
(5,504 Views)
But it looks like we have to pass pointers while calling the function. How to do that ?
I have attached dll descreption pdf.
Adarsh
Architect
Message 7 of 12
(5,499 Views)
Can any one help me out to devloping Sample code which is provoided in attached pdf file(Page 126) using LabVIEW. ?
Adarsh
Adarsh
Architect
Message 8 of 12
(5,489 Views)
I am still waititng for the reply.
Adarsh
Adarsh
Architect
Message 9 of 12
(5,451 Views)
Hi Adarsh,
as i already wrote, you can use the call library function node. There are options to send a pointer or to get data from your dll. Please see the before attached link.
Mike
Message 10 of 12
(5,444 Views)
